Radius - disabled or disabled - cant enable
I am trying to enable Radius client . If I click “Disable” , the lower status bar on the window says “disabled” in light grey. If I click “Enable”, the lower status bar says “disabled” but it is dark grey. I cant turn it on!
I noticed in the title bar in winbox it says "Radius Server "
I also noticed in SSH/Telnet → Radius it says “Flags X: Disabled”
Is the Radius client crippled on this box? Its a RouterBoard and I just upgraded to 2.9.1. (It did the same thing with 2.9rc8)
Whats going on? Thanks!
When disabled is displayed in light grey it’s actually enabled. When it’s dark grey, it’s disabled.
“Flags X: Disabled” is just telling you that any service marked with X is disabled.
Regards
Andrew
Thank you. Ive got it authenticating against my FreeRadius now.
Now I’d like to figure out how to make it auto-send the MAC address as the username, and some string as password, instead of prompting the user for a username/pass.
I got MAC username auth working with the DHCP radius feature.
