Radius-mac-authentication not working with nv2
Hello, i couldnt fint a proper answer for this only in this topic below it is disscused
http://forum.mikrotik.com/t/v6-40-4-current/112822/1
So my question is is there a way or will mikrotik fix Radius mac authentication?
We are quite a big ISP with over 200k clients from which are about 30k via radio on MT hardware.
So far we used security profile setup in which we using few different types of auth for certain stations (CPE, B2B, P2P) they are using different ciphers with auth types.
I have a problem with APs for clients PTMP where are only nv2 stations connected , thus on AP is set only NV2. But in new ROS version if NV2 is set security profile will dissaper, opening new tab NV2 where security + preshared key can be filled but still no Radius server.
I dont want to set “nv2 nstreme 802.11” on APs because then other then NV2 stations can connect, we are using this tripleoption only on CPE units for easier reconnection to different AP.
Is there some1 from miktorik staff who can confirm or deny if radius-mac-auth will be working again with pure NV2 protocol set in newer ROS versions ? I would have to manually change all the setups on APs with this configuration and fill the NV2 tab, also all templates we use for automatical provision via our system would have to change etc.. quite a lot of work.
