Radius mac-caching-time not working
Hi!
I’ve implemented radius authentication in a wireless profile. All works fine, except the mac-caching-time, wich is defined to 00:00:30. This configuration is not working, because the Mikrotik asks to radius once when a new MAC tries to associate, and seems to keep the result in cache forever. If I disable and enable the interface, it asks radius again. I’m using RB433AH with v5.5.
I have found this topic without solution, but is very old… http://forum.mikrotik.com/t/mikrotik-3-x-and-troubles-with-mac-caching-enabled/22446/1
Any hint?
Thanks in advance.
Denilson
Same behavior since 4.11 to 5.15.
Does it simply won’t work? Neither an answer from the team?
Denilson
Have you sent an email to support@mikrotik.com with your issue?
If not, create an supout file and send an email to them explaining this.
Best regards,
from what I have just tested with a 5.20 AP, the time unit of the radius-mac-caching parameter should be in minute.
If I set a station to be rejected in Radius and the radius-mac-caching to :
interface wireless security-profiles set 1 radius-mac-caching=1
RouterOS shows :
radius-mac-caching=1s
but the log with radius and wireless details show that radius requests are done every 2min.
If I set radius-mac-caching=2, requests are done every 4min.
I guess the base unit of radius-mac-caching is more “minute” than “time interval”.
