Radius Manager, WIFI ACL and queues
Have Radius manager running. Was experimenting a bit with authentication of WIFI panel onto a AP. Use the radius to authenticate users onto a hotspot at which time a simple queue is automatically created for the user, dependent on the radius manager settings. What i am wondering is if it would be possible to assign a user a simple queue in the same way when he authenticates onto the AP depending on the Radius Manager settings? Any info would be appreciated.
Anyone can help me here, to fine tune my PPPoE connection with DMA RADIUS Server,
Using Mikrotik RouterBoard 1200, I configure the basic PPPoE connection to my DMA RADIUS
When I connect PPPoE from my PC it was successfully connected, i got my desired IP pool from my RADIUS, however, my Default Gateway and Subnet mask are totally deferment GW 0.0.0.0 and SN M 255.255.255.255, is this normal for PPP? if yes then how can i configure to have an internet access based on my diagram below:
Help please…
