So I have FreeRadius running on a FreeBSD server doing auth for a Aruba WAP system. This works great. Moving to WPA3 this week..
I decided to explore Mikrotik Radius as this would free me from having a seperate server.
After playing with Radius and User Manager.. I can’t get it to work. I must be doing something wrong.
A few questions. On FreeRadius this is all very easy. You create a client and you create a user. Done. I tried following some of the manual wiki pages and watched some youtube vids and I guess i just dont get it.
So do I need to use user manager ? Why not just use the Radius server in the OS and use the “users” ? Im not sure i understand how to link UserManager with the radius server.
Is there a step by step someplace I missed ? Most of what I read seemed to be for internal auth, where I want to have external devices ( Aruba ) connect to the Radius server on the Tik..
As no one else seems to offer a more qualified answer - the User Manager is a Radius server itself. So there is no need (and no way) to use both - either use User Manager (which has some limitations, e.g. cannot support EAP authentication until ROS 7 gets released), or use the external Radius server.
In order to use this authentication, the RADIUS server must support these ciphers. Also, WPA3 192-bit security will be exclusive for EAP-TLS, which will require certificates on both STA and RADIUS server.
