I’m setting up Hotspot and User man according to the wiki on version 3.0b6. Everything goes well until i try to log in to the hot spot, i get Radius server is not responding in the log messages.
I’ve tried doing a sys reset and doing the config again but no luck . Folowing the same directions on 2.9.40 i was able to get it all working.
anyone seen this?
tks
EDIT: here is an export from the hotspot, radius and user-man:
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
name="default" rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
use-radius=no
add dns-name="" hotspot-address=10.5.50.1 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 \
login-by=mac,cookie,http-chap,http-pap mac-auth-password="" name="hsprof1"
nas-port-type=wireless-802.11 radius-accounting=yes \
radius-default-domain="" radius-interim-update=received \
radius-location-id="" radius-location-name="" rate-limit="" \
smtp-server=192.168.1.106 split-user-domain=no use-radius=yes
/ip hotspot user profile
set default advertise=no idle-timeout=none keepalive-timeout=2m name="default"
open-status-page=always shared-users=1 status-autorefresh=1m \
transparent-proxy=yes
/ip hotspot
add address-pool=hs-pool-2 addresses-per-mac=2 disabled=no idle-timeout=5m \
interface=wlan1 keepalive-timeout=none name="hotspot1" profile=hsprof1
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add comment="" disabled=no name="admin" password="******" profile=default \
server=hotspot
/radius
add accounting-backup=no accounting-port=1813 address=10.5.50.1 \
authentication-port=1812 called-id="" comment="" disabled=no domain="" \
realm="" secret="******" service=hotspot timeout=300ms
/radius incoming
set accept=no port=1700
/tool user-manager credit
add comment="" extend-price=unavailable full-price=500 name="5" \
subscriber=admin time=1m
/tool user-manager customer
add comment="" disabled=no login="admin" parent=admin password="*****" \
permissions=owner subscriber=admin time-zone=+00:00
/tool user-manager router
add comment="" disabled=no ip-address=10.5.50.1 \
log=auth-ok,auth-fail,acct-fail name="router1" shared-secret="******" \
subscriber=admin
/tool user-manager user
add comment="" disabled=no name="demo" password="demo" subscriber=admin
add comment="" disabled=no name="hd2k9" password="******" subscriber=admin
