radius pppoe .... 2 connections 1 username !!
Hi all
Might be my mistake in the settings
But what I have done is the following
making Server for pppoe
making a special file for ppoe
from the file in limit make only one (yes)
And then tried to contact two connection with the same name and it have been contacted by all
This is the picture
What is your opinion & suggestion !!
regards
Update
When I added the user name by winbox
The result was that the second connection fail
This means that the problem in radius not as I think from my profile setting !
yes, RADIUS should control that for you
Thats it Chupaka …its BUG
Well …Mikrotik you should Work to repair the imbalance in the next version …
no, you don’t understand me… RADIUS MUST do this check. only authorization should check simultaneous use. if you use RouterOS’s ‘PPP Secrets’, then RouterOS checks simultaneous use. if you use RADIUS - use RADIUS’s capabilities for checking
anyway, it would be nice if ROS can still check it for those who cannot setup RADIUS correctly =)
Well, the proverb said
((No one born philosopher))
this my preparation
if i have mistake in another options … where can i find it .
thanks for your kind help :smiley:
is User Manager your RADIUS?.. then you should probably ask here: http://forum.mikrotik.com/viewforum.php?f=10
Hi all,
Mikrotik V 3.x should not support Simultaneous Use. No choose to do it but
you can write script support it, please see: http://forum.mikrotik.com/t/pppoe-with-userman-and-simultaneous-use/24862/1
