When I try discconect user with “-” in username ,
etc. ,
… I recived this in log “Error-Cause = 406” ,
… 406 Unsupported Extension … by who , mikrotik or radius ?
etc. ,
it must be a mikrotik error…radius wont stop you from disconnecting a user.
regards,
Asad
now I see this…
.. if user have “-” , etc. disconnect work fine,
but , if I try disconnect user with “-1” , etc. , (ghost or second login with same username), I recived error 406
my script find username with “-” over snmp, and send disconnect request for that user,
I try with this to resolve problems with ghost user
The pppoe and 1 part are added by Mikrotik, it’s not the username.
How exactly are you trying to ‘disconnect’ this user?
script read OID (simplequeue), and recived
then used username-1 , put in disconnect request and send to radius …
radius send request to mikrotik …
but mikrotik have error 406 and put request in Naks.
mikrotik have username with -1, but this “-1” make mikrotik and probably this is problem ?
Strip the pppoe and -1 parts. Mikrotik adds them internally.
Best would be to use the Radius Accounting data, you need far more than just a username to send a radius disconnect message…
