Radius & PPTP
question, maybe BFU :wink:
  • how I can set ,Local IP, address for PPTP user when is authorizing over Radius ? If I not have set this IP in default profile in PPP, users are after authorizing at Radius disconected
/Tomi
why not just set it in profile? =)
You have to set Local-Address in a profile, it can’t be done via Radius
because I have some VPNs what have differenet Local IPs than others (for example LAN-to-LAN VPN have another local ip than Remote Users)
and another q, its possible select Profiles over radius ?
No, you can’t.
  1. use mutiple profiles, or
  2. rethink what you are doing.
Based on what I am reading, there should be better ways to achieve what you want…
how you mean that multiple profiles ? Profiles is only for Local Users, not ? And I talk about radius.
I have multiple profiles and they are assigned to each group of users, but its Local and I want move it to Radius.
I have the same problem but it seems that the solution has not been found… or i missed something :confused:
Is there a way to specify, by RADIUS, which profile to use?
Regards
omg… please explain why do you need that =)
In fact, the client connect to the server through two pptp tunnels (each one related to a different link support), so both get the same gateway…
  • diagnosing by which one traffic goes (from a traceroute from lan side) is almost impossible
  • I worry about possible mixing in routes
Specifying server local-address seems to be impossible from RADIUS, it has to bet set in profile, so the last solution (before having to set all logins ā€œppp secretsā€ would be to have two profiles with different local-address and choose which one to use from RADIUS…
Maybe there’s another way but i don’t know which one…
you may set ā€˜local-address’ to almost anything you want - I just don’t understand why do you need to vary it…
do you use public addresses? if no - you may just use different address pool to distinguish clients from the LAN side…
I use RADIUS on the hotspot, and the attribute ā€œMikrotik-Groupā€ selects ā€œ/ip hotspot user profileā€. I enter a profile in ā€œ/ip hotspot user profileā€ named newprofile, then I return ā€œMikrotik-Group=newprofileā€ with the Access-Accept message. Does that sound like it might work with this protocol?
I don’t know if SurferTim message is a question or a suggestion, anyway I don’t know if its setup works, it might, in hotspot mode, but when not using this mode?
My PPTP client is not a hotspot…
Any idea?
It is both. To be honest, I learned of the Mikrotik-Group by ā€˜playing’ with the OS. Same way I figured out radius-default-domain. Set up a test. Use parameters that you would certainly be able to tell the profile was changed. Try not to affect any other profiles with the test if the router is in service.
I am certain that the router I play with would rather be anywhere but here. I torture it regularly. :smiley:
I tried Mikrotik-Group it has no effect, with different operators ā€œ:=ā€ ā€œ=ā€ ā€œ==ā€
radius-default-domain is a hotspot parameter… so it has no effect on pptp server…
Another idea :frowning:
Just a thought. I checked the docs in the radius section, and ā€œMikrotik-Groupā€ appears to apply only to ā€œ/user groupā€ and ā€œ/ip hotspot user profileā€. :frowning:
EDIT: I see your next post. Didn’t want to add another post. If anyone can do it, it will be Chupaka.
Maybe Chupaka will have a magic idea… hope so…
