I have having the radius accounting problem. I have attached the file. Please someone suggest me something.
Try increasing the radius timeout value. It helped me.
/radius
print detail
set 0 timeout=2s
will try that…thanks.
how is your radius configured between router and radius server?Are you using NAT or does the router authenticate to the radius server directly?
If using NAT make sure your router is forwarding Accounting packets to the radius server UDP 1813
This doesn’t work for me…
I am using Usermanager. That means I’m not using NAT.
post a copy of your hotspot config so i can take a look
/ip hotspot export
[admin@ACE] > ip hotspot export
jan/13/2012 21:51:31 by RouterOS 5.11
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=ACE http-proxy=0.0.0.0:9090 login-by=http-chap,http-pap name=
default nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=received
radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0
split-user-domain=no use-radius=yes
/ip hotspot user profile
set default advertise=no idle-timeout=15m keepalive-timeout=5m name=default open-status-page=always shared-users=1
status-autorefresh=5s transparent-proxy=yes
add advertise=no idle-timeout=15m name=hotspot open-status-page=always shared-users=1 status-autorefresh=5s
add advertise=no idle-timeout=15m name=sulav open-status-page=always rate-limit=8k/16k shared-users=1 status-autorefresh=5s
/ip hotspot profile
add dns-name=ace.net.np hotspot-address=0.0.0.0 html-directory=ACE http-proxy=0.0.0.0:9090 login-by=http-chap,trial name=
hsprof1 nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=1m
split-user-domain=no trial-uptime=5m/4w2d trial-user-profile=hotspot use-radius=yes
/ip hotspot
add disabled=no idle-timeout=5m interface=LAN keepalive-timeout=5m name=HS-Server profile=hsprof1
/ip hotspot ip-binding
add address=10.5.50.2 disabled=no mac-address=00:C0:26:69:A1:26 type=bypassed
add address=10.5.50.3 disabled=no mac-address=00:18:F8:84:05:8A type=bypassed
add address=129.75.168.1 disabled=no mac-address=F4:EC:38:C9:1B:32 type=bypassed
add address=129.75.168.2 disabled=no mac-address=B0:48:7A:CA:4A:1A type=bypassed
add address=129.75.168.125 disabled=no mac-address=00:C0:26:69:A1:26 type=bypassed
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept comment="Allow hotspot users to ping for troubleshooting purposes" disabled=no protocol=icmp
jan/13/2012 21:56:42 by RouterOS 5.11
/ip hotspot profile
name=default nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=received
/ip hotspot profile
/ip hotspot
