I am wondering if MT should work with a reply sent from Freeradius “Mikrotik-Xmit-Limit-Gigawords” It’s being sent back after login. I can see it in the MT logs so I know the radius is sending it but the mikrotik router is not doing anything with it? I suspect it only accepts “Mikrotik-Xmit-Limit” which I have tested and works. I really need to be able to send the Gigawords value though if possible?
Can anyone confirm my theory or say if it’s a bug?
Thanks in advance.
