RADIUS server and 802.1x
Is it possible to make an AP with 802.1x authentication through user manager users?
I’m trying to make this configuration but i can’t manage putting it to work.
No, User Manager does not support it.
You need the following scenario,
client — MikroTik AP — RADIUS [FreeRADIUS or any other].
MikroTik AP configuration,
  • radius client with wireless settings.
  • wireless interface, interface wireless security-profile add mode=dynamic-keys eap-methods=passthrough authentication-types=wpa2-eap
Ok thanks, i could try my whole life with user manager, since it doesn’t support it :slight_smile:
I will try free radius than.
Is there any tutorial on how to configure MT and freeradius besides Ramona tutorial, which is ‘a little’ outdated? :slight_smile:
All you need to have on MikroTik,
Any settings required on the wireless client? Or does the default security profile suffice, since all the authentication is taken care of by the NAS and RADIUS?
As far as I know you can use only EAP-TLS with 802.1x, when MikroTik RouterOS is being used as client.
