I get Radius server not Responding When I try to autentificate to hotspot using freeradius.
If you had this issue happened to you and you solved it, post your solution here.
Thanks, I hope this Topic helps troubleshuting this in the future.
I solved by loggin with the radius server to mikrotik hotspot using the default admin account, then it all works fine ![]()
