HI Every ONE
I would like to know has anybody ever done such Setup which I’m going to describe?
I have Radius Server and Everything Is FINE. My radius Server Can Authenticat, Authorize and Account my user.
But I have Problem with wireless clients disconnections
Here My Setup
Sending Disconnect-Request of id 226 to 192.168.12.4 port 1701
User-Name = "00:17:9A:AF:BD:6F"
That was my Radius Server’s Screen
Now You can See logs From MIKROTIK
/ radius incoming
set accept=yes port=1701
echo: radius,debug,packet received Disconnect-Request with id 228 from 192.168.254.44:32771
echo: radius,debug,packet Signature = 0x941ebac7825b9997fe4c639e4fb06f73
echo: radius,debug,packet User-Name = "00:17:9A:AF:BD:6F"
echo: radius,debug received remote request 53 code=Disconnect-Request from 192.168.254.44:32771
I want to know what is my mistake, that MIKROTIK DOES NOT DISCONNECT WIRELESS CLIENTS,
I Know I can Disable Unwanted client MAC address in my MYSQL Database but I need to disconnect them
Uldis Now I have 3.0rc5 running on my router but I am having problems with PPPOE,
21:14:05 system,info,account user admin logged in from 192.168.254.25 via telnet
21:14:46 system,info system identity changed by admin
21:15:00 pppoe,info PPPoE connection established from 00:13:A9:02:24:80
21:15:00 pppoe,ppp,info <pppoe-0>: waiting for call...
21:15:00 pppoe,ppp,info <pppoe-0>: authenticated
21:15:01 pppoe,ppp,info <pppoe-0>: terminating... - could not determine remote IP address
21:15:01 pppoe,ppp,info <pppoe-0>: disconnected
21:15:05 pppoe,info PPPoE connection established from 00:13:A9:02:24:80
21:15:05 pppoe,ppp,info <pppoe-0>: waiting for call...
21:15:05 pppoe,ppp,info <pppoe-0>: authenticated
21:15:06 pppoe,ppp,info <pppoe-0>: terminating... - could not determine remote IP address
21:15:06 pppoe,ppp,info <pppoe-0>: disconnected
21:15:19 pppoe,info PPPoE connection established from 00:13:A9:02:24:80
21:15:19 pppoe,ppp,info <pppoe-0>: waiting for call...
21:15:19 pppoe,ppp,info <pppoe-0>: authenticated
21:15:20 pppoe,ppp,info <pppoe-0>: terminating... - could not determine remote IP address
21:15:20 pppoe,ppp,info <pppoe-0>: disconnected
[admin@NAS-ROUTER] >
please email to support@mikrotik.com with the support output file from your router.
Looks like you need to check if the configuration on the PPPoE server is OK (ppp profiles,ppp secrets).
Thanks Uldis I found My Problem And Now It is workin well.
Yes You are Right I was having Problem with my PPPOE Server Configuration
With Regards
Karo Aznavuryan
