Radius Server Setup
Good afternoon,
Trying to setup a mikrotik router with authenticating users via a radius server. We don’t want use active directory with network policy and cert authentication. I read about setting this up through mac address authentication but is there a way to do this easier as what do you do when you have to update the mac addresses constantly?
Just curious to see if there is another way to authenticate users not through the mac address or through AD?
Also, could someone provide a step by step process of setting this up on a mikrotik router, I have the User Manager files added but do I set the address of my radius server as the address of the mikrotik router?
thanks
So I got it working where if i initially connect via PSK, then add the mac address to the access list. The wireless will only connect while I have the mac in the access list. If I remove it, I cannot connect to the SSID. Is there a way to get this working similar to this via user manager? Also, am trying to get this to work where we have multiple locations and if someone connects at location A and then comes to location B they will connect seamlessly to wifi.
thanks
