radius server + usermanager to bullet for lan auth
hi . im running succesfullly a metal 2shpn with an omni antenna in my hotel almost 3 months now using radius server with usermanager. recently i decided to create a room with 4 lan pcs so people can log in there if they dont have a pc or laptop with them. so i installed a bullet on station mode(bridge) and with a switch i connected the 4 pcs. everything runs fine , the users get on the auth page and they log in with the right usermanager accounts . the problem is that after a user logs in, the pcs stay online forever. i mean that hotspot doesnt check for idle time or keep alive command or anything like this. also the ip of the pc doesnt appear in the session logs of usermanager. any ideas? every help will be appreciated.
thanks in advance and sorry for my english
be sure to check the network diagram, this should maybe be your diagram
MT → HUB → Bullet & cable to rooms
or check yout userman profile settings..
