Radius server
hi all
i want to choose radius server to work fine and compatible with mikrotik.
i’m going to use radius server for large enterprise network with thousands of users.
what windows based radius server you suggest?
thanks
FreeRADIUS works ok. I haven’t tried it with that many users, but should not be a problem. User Manager should also do ok if you don’t need any custom stuff.
thanks
but is it possible to install FreeRadius on windows?
I haven’t tried it, but check this out:
http://freeradius.net/
And there is IAS. A Google search should answer basic questions about that.
