Radius SSTP NPS [SOLVED]
I have OSPF setup on a intranet, the internet facing router is running sstp vpn which works fine. When i try and switch to radius auth for sstp the radius packets never reach the nps server. I have confirmed the nps server is working correctly and that the “radius client” is setup correctly. I have ran wireshark on the nps server and i never see any packets from the router, also torch never shows the connections either. the connection shows only under /ip firewall connections on the WAN router. Its not a connectivity issue between the wan router and the nps because i can ping and telnet in the the server from the router. Its like the radius does not respect the routing table on the WAN router so the packets go no where. Tried on 6.7, 6.15, 6.17 with the same results
                                           [INTERNET]
                                               WAN
                                        10.100.0.254/24
                             [10.100.0.1/24]
                                  rb1100
                           [10.11.15.254/20]
                       NPS (Radius)
                     [10.11.0.2/20]
Nevermind. Fixed my issue. It had nothing to do with routeros. I completely forgot that there is a transparent content filter inline and it was blocking incoming radius packets for some reason.
