Hi
Im experimenting a weird issue after migrating my router from RB1100 to CCR1009.
everything was working fine when few users connect to the VPN over radius and statics ips.
after the migration on Windows Radius i assing the static ip address Example 172.16.3.99
i check the log and the Framed-IP-Address parameter is correct
https://imgur.com/a/OEvn1 (for one reason images are not loading on forum)
when the user get connected the assigned IP address is.
https://ibb.co/h8R3FS (for one reason images are not loading on forum)
if you see the address is complety backwards instead of 172.16.3.99 is 99.3.16.172
also i install a CHR on my lab and i can get the same issue.
the weird thing is my old router RB1100 in 6.41.2 if i plug back works perfectly.
Someone can guide me on how to solve this issue. i Already put a support ticket but is a little bit hard to trobleshoot with them.
