Hi All,
I am having problem with radius timeout on usermanager, it did this when I first setup userman as well.
I setup radius manager the first time with ip addresses assigned to all my interfaces, and it came with error of radius time out, so I added another router in the setup, this registered two sessions per host, but the radius worked, all the accounting was double. I removed the second router a week later, and radius timeout error dissappeared. I had to replace a wireless card recently, and the radius timeout appeared again.
I add the second radius ip in /radius and it works, but now registering two sessions for every connection, thus doubleing accounting. If I remove the second radius it comes with radius timeout error again. If I remove the IP assigned to all other interfaces except for one, then it works again.
I have been using userman since 2.9.29 and have only experienced these issues on v3+
My Usermanager setup bellow:
[stephen@Stephen-433] /interface pppoe-server server> print
Flags: X - disabled
0 service-name="winagain" interface=ether1 max-mtu=1480 max-mru=1480
mrru=disabled authentication=pap,chap keepalive-timeout=10
one-session-per-host=yes max-sessions=0 default-profile=default
1 service-name="winagain" interface=ether2 max-mtu=1480 max-mru=1480
one-session-per-host=no max-sessions=0 default-profile=default
2 service-name="winagain" interface=wlan1 max-mtu=1480 max-mru=1480
3 service-name="winagain" interface=wlan2 max-mtu=1480 max-mru=1480
4 service-name="winagain" interface=wlan3 max-mtu=1480 max-mru=1480
5 service-name="service1" interface=ether1 max-mtu=1480 max-mru=1480
mrru=disabled authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10
one-session-per-host=no max-sessions=0 default-profile=profile1
6 service-name="service2" interface=wlan1 max-mtu=1480 max-mru=1480
7 service-name="service3" interface=wlan3 max-mtu=1480 max-mru=1480
[stephen@Stephen-433] /radius> print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 ppp 192.168.30.221 testing123
[stephen@Stephen-433] /tool user-manager router> print
Flags: X - disabled
0 subscriber=admin name="router1" ip-address=192.168.30.221
shared-secret="testing123" log=auth-ok,auth-fail,acct-fail
[stephen@Stephen-433] /tool user-manager customer> print
Flags: X - disabled
0 subscriber=admin login="admin" password="admin" time-zone=+00:00
permissions=owner parent=admin signup-allowed=no paypal-allowed=no
paypal-secure-response=no paypal-accept-pending=no
[stephen@Stephen-433] /ppp profile> print
Flags: * - default
0 * name="default" local-address=192.168.30.221 remote-address=ppp-clients
use-compression=default use-vj-compression=default use-encryption=default
only-one=default change-tcp-mss=yes
1 name="pppoe-out" use-compression=no use-vj-compression=no use-encryption=no
2 name="profile1" local-address=192.168.30.221 remote-address=ppp-clients
use-compression=no use-vj-compression=no use-encryption=no only-one=no
change-tcp-mss=yes incoming-filter=""
3 * name="default-encryption" use-compression=default use-vj-compression=default
use-encryption=yes only-one=default change-tcp-mss=yes
If I have missed any of the exports let me know, I will post them.
Hope someone will be able to make heads or tails on this!
