Hey All,
So I’m currently trialing using the Azure AD MFA with our NPS server to provide MFA protection for VPN connections (SSTP) and I’m running into issues with Radius timeouts. Given that it takes a couple of seconds to show the push notification in the mobile app, you have to be really quick on hitting ‘Approve’ for the authentication to not timeout when set at the maximum of 3000ms.
Is there any scope to be able to specify a higher value? Allowing it to a maximum of 10 seconds should allow you to be able to get push notification, unlock phone, load app, get notification, press approve.
– Marc
