RADIUS usage accounting problems
what are you talking about? if there is a previous topic you are referring to, please include a link
  1. It is not actually a bug and was explained further in the topic
    It was never explained
Yes, it was.
http://forum.mikrotik.com/viewtopic.php?f=2&t=45451&p=229814#p229363
  1. Thank you for the report, bug noted and will be fixed in one of the next versions
    You just told me it was not a bug?
Where exactly it is told? Only answer about second problem is as you see above, that bug will be fixed in next version.
  1. There were problems with connection marks which is fixed and fix will be included in RC2
    This does not relate to my problem at all.
Only known problem was related to connection marks which is fixed. If something else is not working correctly please specify what exactly. Your statement
Mangle rules completely not working under version 5.0rc1.
does not help because mangle rules work for others.
Regards,
Maris
Seems that there was some misunderstanding, because support ticket contained only link to this forum topic without any further explanations:
http://forum.mikrotik.com/t/too-many-bugs/41161/1
As you mentioned that radius problem does not appear consistently, so we will need more testing to find the problem and fix it.
