I am using windows based radius server to auth users of hotspot servers. It authenticates fine. But rate-limit does not work even if i add mikrotik-rate-limit attribute on radius in access-accept. Second and very interesting thing is when i try to use PCQ for bandwidth control that also doesn’t work when user is authenticated using radius but same PCQ works fine when change auth to local.
( I know user manager is good but i can not integrate it with my other operations as it dooes not have any method to access in RDBMS format or somthing like that)
Any suggestions NORMIS
GoodOne
