I use WPA2 - EAP for wireless client auth. I dont want to use hotspot. As a radius server, I use Freeradius. I need to limit bandwidth for users so I have tried to use attribute Mikrotik-Rate-Limit, but no Simple Queue entries were created upon users connection. So .. is there a way how to achieve this?
The thread looks a bit older, but I have the same question.
Currently I try with a two way solution. One code for WPA2 a second one for hotspot login to get the bandwidth.
Radius is FreeRadius 2.1.something.
I’ve finally achieved this by enabling tunneled reply in my freeradius.
Now a strange behavior incurs: Mikrotik-rate-limit works only for downstream. Upstream bandwidth seems unlimited.
Here is my freeradius attributes response:
Here is my Gw situation:
Any ideas? Is there a way to achieve speed limitations even for Upload?
i think this is a ROS bug.
