RANCID Config Backup
Has anyone gotten RANCID (http://www.shrubbery.net/rancid/) to work with Mikrotik Routers?
It looks like someone has attempted this (http://www.gossamer-threads.com/lists/rancid/users/3826) but I’ve not had any luck getting his patch to work.
If anyone has this working, please let me know. I could use some tips.
I was able to get Rancid updated so that it will login properly & get the configs.
However, it seems to only fully work when you manually run it.
Something about the automatic running is causing an error.
Trying to get all of the configs.
br1.prn: missed cmd(s): system routerboard print
It tries 4 times, then quits and never actually saves the config.
But if you use
rancid-run -r <router-name>
It runs just fine and gets all the changes.
Anybody else seen this behavior?
*Update: Oh, I forgot to mention it only works with version 3.x because the login script is adding +ct to the end of the username. Which in 3.x turns color off, and automatic tabbing maybe? 2.9 doesn’t know what to do with that, so it just assumes your username is wrong.
-Keith-
RNS
Chiming in that that patch works fine for me, tested on routerboards running 4.11. It doesn’t patch cleanly against the current version so I wrote a little page and have the files available for download here:
One thing I notice is that RouterOS seems to randomly generate the mac address that’s listed under /interface ovpn-server server even though I’m not using it and that’s causing the config to be different each time.
Note that my above files and instructions are for FreeBSD, paths to where to put them may be different on your system. Also the paths to perl and expect at the beginning of each file may vary slightly as well.
You are correct about the ovpn thing. That plagued me for a bit.
I found that if you set a bogus mac, it stops. And doesn’t actually turn on the ovpn-server
/interface ovpn-server server set mac-address=00:00:00:00:00:01
-Keith-
Thanks, makes sense. For what it’s worth I joined the RANCID mailing list to post a request to add their patch to be official. It may gain more traction if other Mikrotik+RANCID users were to chime in and say they use this functionality.
change:
{‘system package print detail’ => “SystemPackagePrintDetail”},
to
{‘system package print detail without-paging’ => “SystemPackagePrintDetail”},
Hello
mtrancid stoped parsing if mikrotik script have
example:
test@MikroTik_1000] > system script export
add name=timeout_winbox policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source=":log error(\"test\
    );\r\
               [:len [:find [/ip firewall connection get $c dst-address] (":" . [/ip service get winbox port])]] > 0) do={
how about
$prompt = "\\[9999B\\[\\w+\@\\w+\\] >\\s*";  # crude but effective
  • if mtlogin output have:
   \n/export file=([/system identity get name] . \"-\" . [:pick [/system cloc\^
    k get date] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system\^
or
add comment="" disabled=no down-script=":foreach i in=[/ip route find (static \^
    gateway=10.10.3.13 dst-address=192.168.0.0/24)] \\ do={/ip route disable \^
mtrancid output:
/system cloc k
and
staticgateway=10.10.3.13
how about
RouterOS splits long lines with backslashes - this joins them back up
if (/\\n$/) {
s/\\n$//;
$buffer .= $_;
if (!/=$/ && !/=“[^”]+$/ ) {
$buffer .= “”;
I followed the installation steps on the internet however, I’m having problems getting Rancid to recognize the “mikrotik” router name I created.
Any help would be greatly appreciated. Below is the error I’m recieving:
-bash-3.1$ more mikrotik.20110322.213618
starting: Tue Mar 22 21:36:18 CDT 2011
exec failed router manufacturer mikrotik: No such file or directory
Getting missed routers: round 1.
Getting missed routers: round 2.
Getting missed routers: round 3.
Getting missed routers: round 4.
cvs diff: Diffing .
cvs diff: Diffing configs
cvs commit: Examining .
cvs commit: Examining configs
ending: Tue Mar 22 21:36:18 CDT 2011
-bash-3.1$ cat var/mikrotik/router.db
172.16.0.254:mikrotik:up
%vendortable = (
‘agm’ => ‘agmrancid’,
‘alteon’ => ‘arancid’,
‘arista’ => ‘arrancid’,
‘avocent’ => ‘avorancid’,
‘baynet’ => ‘brancid’,
‘cat5’ => ‘cat5rancid’,
‘cisco’ => ‘rancid’,
‘cisco-nx’ => ‘nxrancid’,
‘cisco-xr’ => ‘xrrancid’,
‘css’ => ‘cssrancid’,
‘enterasys’ => ‘rivrancid’,
‘erx’ => ‘jerancid’,
‘extreme’ => ‘xrancid’,
‘ezt3’ => ‘erancid’,
‘f5’ => ‘f5rancid’,
‘force10’ => ‘f10rancid’,
‘fortigate’ => ‘fnrancid’,
‘foundry’ => ‘francid’,
‘hitachi’ => ‘htrancid’,
‘hp’ => ‘hrancid’,
‘juniper’ => ‘jrancid’,
‘mikrotik’ => ‘mtrancid’,
‘mrtd’ => ‘mrancid’,
‘mrv’ => ‘mrvrancid’,
‘netopia’ => ‘trancid’,
‘netscaler’ => ‘nsrancid’,
‘netscreen’ => ‘nrancid’,
‘procket’ => ‘prancid’,
‘redback’ => ‘rrancid’,
‘riverstone’ => ‘rivrancid’,
‘smc’ => ‘srancid’,
‘tnt’ => ‘tntrancid’,
‘zebra’ => ‘zrancid’,
Check the first line of mtrancid and mtlogin. They need to point to perl and expect on your system. The values that come with the scripts are probably nor right for your system.
First off thanks for all the info that was here already, it has helped a lot. I have gotten everything situated and I am stumped on a fairly simple spot, what syntax do you use to define the password for the mikrotik? No one seems to have covered that, do I define it just like the cisco passwords even though there is no “enable” password? Thanks in advance!
Going to necro this thread back to life,
I’ve gotten rancid running and pulling back from a 4.16 route but the diff’s seems to show alot more than whats just changed
  /interface wireless manual-tx-power-table
- set Edge comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps: 17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0 ,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0"
+ set Edge comment=""
+ manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps
+ :17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0
+ :0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40
+ -0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0
It seems to be splitting up some commands at random across lines thus causing a diff, Anyone got any ideas on this?
Does it only happen if you run a backup by hand then later by the cron job?
I used to see this happen if ssh detected my terminal width - I only let the cron job do my backups now.
Interesting point, I’ve run this both time in that diff by ./rancid-run in SSH, I’ll let cron take over and see
It’s not that the name is not being recognized, it’s that the scripts it’s running have errors in the first line which produce “No such file or directory”. Run mtlogin and mtrancid manually and address those issues. Then it should work.
I had to change the following in Falz’s scripts for Debian 6:
mtlogin:
#! /usr/local/bin/expect –
to
#! /usr/bin/expect –
mtrancid:
#! /usr/bin/perl5
to
#! /usr/bin/perl
I am getting the same issue. It seems to be an addition or subtraction of a space. Exactly what pnep posted above.
This goes in mtrancid. After some testing, it doesn’t really fix the issue.
your line splitting is due to your shell environment supplying a terminal width.
if you run via cron (as an example), it shouldn’t define a tty column count and as such shouldn’t wrap.
if you run interactively, your shell will have some column count defined, and the mikrotik shell will wrap to suit.
this will make the lines different and hence diff will spit out changes.
it would be nice for an export no-wrap command for backup purposes :slight_smile:
I have recently installed Rancid 3.2 and have been successful at getting it configured to run against Mikrotik routers. I am processing about 55 routers of varying versions of RouterOS, mostly 5.x and 6.x . The problem I am having, and it is repeatable, is when running the export command the output of the /port section is extremely unreliable, resulting in many different versions. When examining these diffs, I find the following:
revision 1.174 by rancid, Mon Jul 6 19:39:17 2015 UTC revision 1.175 by rancid, Mon Jul 6 20:11:36 2015 UTC
180 /port /port
181 set 0 name=serial0 set 0 baud-rate=115200 name=serial0
182 set 1 name=serial1 set 1 baud-rate=115200 name=serial1
or no port section at all
revision 1.18 by rancid, Thu Jun 25 20:36:10 2015 UTC revision 1.19 by rancid, Thu Jun 25 21:06:15 2015
/port
set 0 name=serial0
set 1 name=serial1
This is extremely frustrating, and can be reproduced in the terminal window in winbox.
Open a terminal window and run /export a few times and examine the output.
When I find no output after the port section, I try to change the baud rate in winbox-System-Ports but when clicking Apply or Ok, I get an error dialog informing me the change cannot be applied because a background process is using the port. ??huh??
This happens across all versions of RouterOS 6. This does not seem to happen in version 5.x
I have already corrected router configs for the ovpn server mac, and the script line breaks in 5.x, if I can find a fix for the missing port section, Rancid will be very useful for tracking intentional changes in router configs.
It is about useless now as the number of changes to view for a days worth of collecting configs every half hour is overwhelming.
Somebody out there must have run into this, care to share?
