Random restart and kernal failure
  1. routeros-7.0beta1-arm.npk
  2. RB4011iGS+5HacQ2HnD-IN
    [admin@MikroTik] > log print
    01:00:00 system,error,critical router was rebooted without proper shutdown
    01:00:00 system,error,critical kernel failure in previous boot
    01:00:05 wireless,info wlan1: pre-shared key authentication not enabled, disable WPS
    01:00:22 interface,info ether8 link up (speed 1G, full duplex)
    01:00:45 system,info,account user admin logged in from 00:26:B9:DB:3B:17 via winbox
    01:00:46 system,info,account user admin logged in via local
    01:01:52 system,info supout.rif file created by admin
    01:02:46 system,info,account user admin logged in via local
    Im getting random reboots with the stock config and kernal failure
from the supout.rig
SWITCH
Columns: NAME, TYPE, MIRRor-source, MIRRor-target
NAME TYPE MIRR MIRR
0 switch1 Realtek-RTL8367 none none
1 switch2 Realtek-RTL8367 none none
PORT
Columns: NAME, SWITCH, Default-vlan-id
NAME SWITCH D
0 ether1 switch1 0
1 ether2 switch1 0
2 ether3 switch1 0
3 ether4 switch1 0
4 ether5 switch1 0
5 ether6 switch2 0
6 ether7 switch2 0
7 ether8 switch2 0
8 ether9 switch2 0
9 ether10 switch2 0
10 switch1-cpu switch1 0
11 switch2-cpu switch2 0
PORT STATS
name: ether1 ether2 ether3 ether4 ether5 ether6 ether7ether8
driver-rx-byte: 0 0 0 0 0 0 0137 236
driver-rx-packet: 0 0 0 0 0 0 01 298
driver-tx-byte: 0 0 0 0 0 0 01 547 152
driver-tx-packet: 0 0 0 0 0 0 01 459
rx-bytes: 0 0 0 0 0 0 0141 160
rx-unicast: 0 0 0 0 0 0 0 0
rx-broadcast: 0 0 0 0 0 0 01 148
rx-pause: 0 0 0 0 0 0 0 0
rx-multicast: 0 0 0 0 0 0 0136
rx-fcs-error: 0 0 0 0 0 0 0 0
rx-fragment: 0 0 0 0 0 0 0 0
rx-unknown-op: 0 0 0 0 0 0 0 0
rx-code-error: 0 0 0 0 0 0 0 0
rx-jabber: 0 0 0 0 0 0 0 0
rx-drop: 0 0 0 0 0 0 0 0
tx-bytes: 0 0 0 0 0 0 01 531 945
tx-unicast: 0 0 0 0 0 0 01 386
tx-broadcast: 0 0 0 0 0 0 0 3
tx-pause: 0 0 0 0 0 0 0 0
tx-multicast: 0 0 0 0 0 0 0 51
tx-collision: 0 0 0 0 0 0 0 0
tx-excessive-collision: 0 0 0 0 0 0 0 0
tx-multiple-collision: 0 0 0 0 0 0 0 0
tx-single-collision: 0 0 0 0 0 0 0 0
tx-deferred: 0 0 0 0 0 0 0 0
tx-late-collision: 0 0 0 0 0 0 0 0
tx-drop: 0 0 0 0 0 0 0 0
tx-rx-64: 0 0 0 0 0 0 0 57
tx-rx-65-127: 0 0 0 0 0 0 01 185
tx-rx-128-255: 0 0 0 0 0 0 0305
tx-rx-256-511: 0 0 0 0 0 0 0121
tx-rx-512-1023: 0 0 0 0 0 0 0160
tx-rx-1024-1518: 0 0 0 0 0 0 0896
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 137 364
driver-rx-packet: 1 300
driver-tx-byte: 1 548 666
driver-tx-packet: 1 460
rx-bytes: 141 160
rx-unicast: 0
rx-broadcast: 1 148
rx-pause: 0
rx-multicast: 136
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 1 531 945
tx-unicast: 1 386
tx-broadcast: 3
tx-pause: 0
tx-multicast: 51
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 57
tx-rx-65-127: 1 185
tx-rx-128-255: 305
tx-rx-256-511: 121
tx-rx-512-1023: 160
tx-rx-1024-1518: 896
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
driver-rx-byte: 0
driver-rx-packet: 0
driver-tx-byte: 0
driver-tx-packet: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
rx-bytes: 0
rx-unicast: 0
rx-broadcast: 0
rx-pause: 0
rx-multicast: 0
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 0
tx-unicast: 0
tx-broadcast: 0
tx-pause: 0
tx-multicast: 0
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 0
tx-rx-65-127: 0
tx-rx-128-255: 0
tx-rx-256-511: 0
tx-rx-512-1023: 0
tx-rx-1024-1518: 0
rx-bytes: 1 543 150
rx-unicast: 1 386
rx-broadcast: 3
rx-pause: 0
rx-multicast: 51
rx-fcs-error: 0
rx-fragment: 0
rx-unknown-op: 0
rx-code-error: 0
rx-jabber: 0
rx-drop: 0
tx-bytes: 151 432
tx-unicast: 0
tx-broadcast: 1 148
tx-pause: 0
tx-multicast: 136
tx-collision: 0
tx-deferred: 0
tx-drop: 0
tx-rx-64: 12
tx-rx-65-127: 1 185
tx-rx-128-255: 305
tx-rx-256-511: 121
tx-rx-512-1023: 160
SWITCH STATS
driver-rx-byte: 0 137 428
driver-rx-packet: 0 1 301
driver-tx-byte: 0 1 561 224
driver-tx-packet: 0 1 461
rx-bytes: 0 129 622
rx-packet: 0 1 301
rx-too-short: 0 0
rx-64: 0 0
rx-65-127: 0 1 014
rx-128-255: 0 225
rx-256-511: 0 26
rx-512-1023: 0 34
rx-1024-1518: 0 0
rx-1519-max: 0 2
rx-too-long: 0 0
rx-broadcast: 0 1 165
rx-pause: 0 0
rx-multicast: 0 136
rx-fcs-error: 0 0
rx-align-error: 0 0
rx-fragment: 0 0
rx-length-error: 0 0
rx-jabber: 0 0
rx-drop: 0 0
tx-bytes: 0 1 540 770
tx-packet: 0 1 461
tx-broadcast: 0 3
tx-pause: 0 0
tx-multicast: 0 51
HOST
Flags: D - dynamic, I - invalid
VLAN
RULE
Flags: X - disabled, I - invalid; D - dynamic
SWITCH STATS
bad command name stats (line 1 column 28)
VLAN
UNICAST-FDB
bad command name unicast-fdb (line 1 column 28)
MULTICAST-FDB
bad command name multicast-fdb (line 1 column 28)
RESERVED-FDB
bad command name reserved-fdb (line 1 column 28)
INGRESS-VLAN-TRANSLATION
bad command name ingress-vlan-translation (line 1 column 28)
EGRESS-VLAN-TRANSLATION
bad command name egress-vlan-translation (line 1 column 28)
PORT-ISOLATIO
Flags: I - invalid
0 name=“ether1” switch=switch1
1 name=“ether2” switch=switch1
2 name=“ether3” switch=switch1
3 name=“ether4” switch=switch1
4 name=“ether5” switch=switch1
5 name=“ether6” switch=switch2
6 name=“ether7” switch=switch2
7 name=“ether8” switch=switch2
8 name=“ether9” switch=switch2
9 name=“ether10” switch=switch2
10 name=“switch1-cpu” switch=switch1
11 name=“switch2-cpu” switch=switch2
PORT-LEAKAGE
bad command name port-leakage (line 1 column 28)
ACL
bad command name acl (line 1 column 28)
