Hello
Something weird happened a few days back and my router just randomly decided to reset itself to default config. Whatever.
The problem is, now I have some weird losses when I ‘initiate’ a connection if that makes sense. So basically open the browser — request timed out for a few seconds. And that persists across every program. It wasn’t a big deal until I tried using remote desktop — when I use it I get the request time outs every 10 or so seconds. They’re fast, not enough to drop connection completely, but long enough to make everything freeze and not respond.
It happens in games, too, and manifests in just a loooong lag (packet loss) while ping stays okay.
The first thing I tried is disabling RSTP, but it didn’t work, and I don’t have the last backup unfortunately. Help please
edit: I should probably add that this is basically the default config it reseted to.
add admin-mac=** auto-mac=no comment=defconf name=bridge
protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=2442 installation=
indoor mode=ap-bridge ssid=Anya wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid disabled=yes
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid disabled=yes
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute”
dst-port=33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
[/quote]
