Hello friends, I am new to mikrotik and I set up a ccr2004-16g-2s+ a week ago, but ever since I installed the new router
I started having connection problems, I can’t access several sites like Facebook, Gmail, YouTube, OneDrive and more. I am using zerotier and the default configuration, all ports are in brigde mode. Additionally, I use a tp link switch.
It fixes if I restart the router I’ve been doing that every day but I can’t be doing that all the time
I would really appreciate your help I anyone knows something about it, I am new to mikrotik and I don’t have a lot of experience
First try to ping website and connect to port 80. You might find DNS problems (i.e “hostname not found”) or connection could be succeed. In this case there might be browser problems.
Without knowing your configuration, we are guessing. Please post a network drawing (or at least a GOOD description of what it connected to what), and a configuration export.
To export and paste your configuration (and I’m assuming you are using WebFig or Winbox), open a terminal window,
and type (without the quotes) “/export hide-sensitive file=any-filename-you-wish”. Then open the files section
and right click on the filename you created and select download in order to download the file to your computer.
It will be a text file with whatever name you saved to with an extension of .rsc. Open that file in your favorite
text editor and redact any sensitive information if desired / needed. Then in your message here, click the code
display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks
like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
Hello again this morning happened again, this time only whatsapp did not work after rebooting it worked, thanks for the help
this is the current configuration
Hi again, after a lot of time searching for the solution I found out that the router of my ISP was faulty so they replaced it, and it worked I no longer have this problem loading web pages
