I am having problem for a long time.
My wifi clients randomly disconnect with following message in log:
18:36:37 wireless,debug wlan1: xx:xx:xx:81:88:DF attempts to associate
18:36:37 wireless,debug wlan1: xx:xx:xx:81:88:DF not in local ACL, by default accept
18:36:37 wireless,info xx:xx:xx:81:88:DF@wlan1: connected, signal strength -83
18:37:24 wireless,info xx:xx:xx:81:88:DF@wlan1: disconnected, extensive data loss, signal strength -83
18:37:43 wireless,debug wlan1: xx:xx:xx:81:88:DF attempts to associate
18:37:43 wireless,debug wlan1: xx:xx:xx:81:88:DF not in local ACL, by default accept
18:37:43 wireless,info xx:xx:xx:81:88:DF@wlan1: connected, signal strength -86
The apartment is very small. There is maximum one wall, but the problem occurs even when I am 2 meters away from the router without walls between us.
Its happening on both bands 2.4ghz and 5ghz.
My device is hap ac with latest firmware 7.5.
I am posting my wifi configuration. If needed I will post more.
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=no \
eap-methods="" group-ciphers=aes-ccm group-key-update=5m interim-update=\
0s management-protection=disabled mode=dynamic-keys mschapv2-username="" \
name=default radius-called-format=mac:ssid radius-eap-accounting=no \
radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-sta-private-algo=none static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=\
no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
3 area="" arp=enabled arp-timeout=auto band=2ghz-g/n basic-rates-a/g=\
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
compression=no country=no_country_set default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=\
yes disable-running-check=no disabled=no disconnect-timeout=3s distance=\
indoors frame-lifetime=0 frequency=2412 frequency-mode=superchannel \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 installation=any \
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
mac-address=xx:xx:xx:51:4C:CC max-station-count=2007 mode=ap-bridge mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 \
nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
on-fail-retry-time=100ms preamble-mode=both radio-name=xxxxxx514CCC \
rate-selection=advanced rate-set=default rx-chains=0,1,2 scan-list=\
default secondary-frequency="" security-profile=default \
skip-dfs-channels=all ssid=iMPERiA station-bridge-clone-mac=\
00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1,2 \
tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 \
wmm-support=disabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=\
3 area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=\
6Mbps bridge-mode=enabled channel-width=20/40/80mhz-XXXX compression=no \
country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no \
disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 \
frequency=5200 frequency-mode=superchannel frequency-offset=0 \
mac-address=xx:xx:xx:51:4C:CB max-station-count=2007 mode=ap-bridge mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=wlan2 \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink \
nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret=\
"" on-fail-retry-time=100ms preamble-mode=both radio-name=xxxxxx514CCB \
skip-dfs-channels=all ssid=iMPERiA-5GHz station-bridge-clone-mac=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 \
tx-chains=0,1,2 tx-power-mode=default update-stats-interval=disabled \
vht-basic-mcs=mcs0-7 vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9 vlan-id=1 \
vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none \
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=802.11 wmm-support=disabled wps-mode=disabled
