Randomly lost lan connectivity
Super easy scenario :
Wifi on hAP AX3 side works fine.
Lan machines can always reach both cAP and hAP bridge ip address
On cAP AX side , wifi clients (that result registered on cAP wifi) lose randomly connectivity to LAN machines, but they can still ping cAP bridge ip address.
cAP and hAP are located in different rooms and they have the same SSID/security.
wifi interface are bridged directly to ethernet but I also configured bridge1 as wifi datapath (with bridge dynamic creation of those ports) same issue.
I used this basic configuration sometimes with no issue at all.
Any suggestion please?
Can you please share configs?
hAP-AX3 :
add name=bridge1 protocol-mode=none
/interface wifi channel
add disabled=no name=NONDFS skip-dfs-channels=all
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=sec1
/interface wifi configuration
add channel=NONDFS country=Italy datapath=datapath1 disabled=no mode=ap name=cfg1 security=sec1 ssid=SSID1
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg1 configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=cfg1 configuration.mode=ap disabled=no
add name=dhcp_pool_1 ranges=192.168.1.101-192.168.1.200
add address-pool=dhcp_pool_1 interface=bridge1 lease-time=6h name=dhcp1
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
/ip dhcp-client
add interface=ether1
add address=192.168.1.0/24 dns-server=192.168.1.1,8.8.8.8 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
cAP-AX :
/interface wifi
add address=192.168.1.251/24 interface=bridge1 network=192.168.1.0
set servers=192.168.1.1
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main suppress-hw-offload=no
I think (it could have changed in very recent ROS versions) that when manually configuring wifi interfaces (as opposed to using CAPsMAN), they have to be made btidge ports manually as well.
As said it’s an already used rOS 7.1x config without any similar issue, anyway I already configured manually bridge ports without improvement…
I was thinking to a radio side issue but cAP bridge is perfectly pingable once wireless device is registered to cAP itself.
The only (troublesome?) thing is an overlap Wifi area where sometimes same wireless device is registered both sides (hAP And cAP) despite issue is present with device closer to cAP with a much stronger RSSI.
STP issues? I see you have turned STP off, but switch in the middle might have it on. We have little to no info about that switch.
Switch is an Aruba JL683B with its default configuration, and RSTP enabled.
I never had issues (also with MT devices having STP turned off).
