Range of MikroTik SXTsq Lite 2
I’ve been searching the internet for an hour and can’t find an answer to this simple question. What sort of distance would I expect to get from a pair of SXTsq Lite 2s? Mikrotik don’t list a range under the product info and most resellers just copy/paste the mikrotik description. I can find one ali express seller that claims 4 kms. Mikrotik do list a distance for the SXTsq Lite 5 but not the 2. Yes I know there’s a lot of factors that will effect it but it’s good to have a starting point. Where I plan to install it is pretty much an ideal situation, out in the country, not much wifi around.
Look up the P2P Guide from Mikrotik
https://mikrotik.com/products/ptp
SXTsq Lite 2 :
MAX 1KM for MCS7
MAX 3KM for 54Mbits
MAX 29KM for MCS0
MAX 32KM for 6Mbits/s
Or maybe try the P2P Link-Calculator from Mikrotik
https://mikrotik.com/calculator
Perfect, thank you
