Rapid Rollout of HAP AC3 routers
We are setting up wireless internet in our local area and want to use some decent router kit at the client end as part of the bundle. The HAP AC3 routers seem to tick all the boxes on price, spec etc. Is there a way I can roll out routers rapidly, so that they can be pre configured with a load of settings e.g., SSID: ABC-SERIALNUMBER, PASSWORD: SERIALNUMBER.
I was hoping there was a way to do that without having to log onto every box and restore the settings and manually change them. Maybe some sort of variables that can be used to import each time to make it less manual?
We are likely to be rolling out maybe 100 - 200 of these so want to make the process as stream lined as possible.
Netinstall + config script
Lazy implementation …
Copy the current default configuration (/system default-configuration print)
Edit that script to your wishes, and maintain variables so you only need one version.
Execute (import) edited *.rsc file, or restart with execution of that file
