Rate Adaptation algoritm
Hello
I wonder what sort of rate adaptation algoitm is used in atheros driver in RouterOS. I,ve got some test of diffrences in performance using three diffrent ways. AMMR, ONOE, and SampleRate. Result shown that Sample is the best on stable links from those three.
As i want to be prepared more in planing of wifi deployment, i would like to know what algoritm is used in RouterOS. is it one of 4 implemented in MaWIFI ? or you made your own ?
Best Regards
Pawel Cieplinski
Probably same as in Linux?
That is question to Mikrotik, right? So why you ask it here? - Write to support., then you can paste their answer here :sunglasses:
RouterOS doesn’t use Madwifi, or any other linux solution for Wireless. I don’t know about the algorithm, though. You should ask support
