Rate limits
hi all
i have rate limit (rx/tx)=90k/144k
why users take more than 150k upload, not max 90k
many thx
Can you post your configuration?
laiman@Slaiman Server] /ppp profile> print
Flags: * - default
0 * name="default" use-compression=default use-vj-compression=default
     use-encryption=yes only-one=default change-tcp-mss=no
 1   name="112 Down   64 UP" local-address=182.10.0.1
     remote-address=Normal Pool use-compression=no use-vj-compression=no
     use-encryption=no only-one=yes change-tcp-mss=no
     rate-limit=64k/112k 256k/256k 128k/128k 10/10
 2   name="160 Down   80 UP" local-address=182.10.0.1
     remote-address=No Firewall Pool use-compression=no use-vj-compression=no
     rate-limit=80k/128k 256k/256k 128k/128k 10/10
 3   name="220 Down   96 UP" local-address=182.11.0.1
     use-encryption=no only-one=yes change-tcp-mss=no rate-limit=96k/220k
 4   name="180 Down   80 UP" local-address=182.11.0.1
     rate-limit=80k/140k 256k/256k 128k/128k 10/10
how did you check the speed while there is no remote address?
i looked at the Rx in ppp–> interface
most customer upload arrive >150 kb
set rate limit 90k/144k,
1 name=“112 Down 64 UP” local-address=182.10.0.1
rate-limit=90k/144k
i’ve tried and it works for me.
