How do we rate limit single interface
in our case ethernet1 to be ratelimited to 1Mbps
Regards
Regards
Just make a queue with the port on it? I have not tried this, but don’t see why it would not work. else, if the port only has one subnet, just add that entire subnet with the 1meg rule ..
If you are using V3 you can do it right on the interface instead of dealing with queues.
I have this setup at one of our locations is works as expected and is very convenient.
