RAW
I don’t seem to be able to drag and drop the order of ip firewall RAW rules within Winbox 3.11. Is this feature coming?
Make sure that your rules are already ordered. If not, you’re no able to move the rules.
Click on “#” to ordering your rules.
My curiosity is why can’t you order them?
I think what pietroscherer is trying to say, is in the RAW tab, on the very left if you notice that your numbers are not in order (1…2…3…4… etc) then you will not be able to move the rules around since they are not in order. If you click on the “#” icon above the numbers until they are in order you will be able to move the rules around any way you want. Ive provided images to help you understand.
  • Mike
Thanks for the input. I restarted and retried and now I can move them. Not sure why I had to but its resolved. Thanks for helping me out.
Thanks Mike!
