I’ve just purchased a RB1000U as an edge router. I’m wondering what type of memory should be used in upgrading it to 2GB. I had noticed someone recommended Kingston non-ecc 677Mhz. Wouldn’t you use ECC over NON-ECC for a router? I’m looking for feedback on types of memory and what your experiences are. Also, I read some where that there is a hardware limitation so the RB1000 can only use 1.5gb, is this true?
Thanks so much!
Richard Cernava
