RB-1000 very bad performance
Hi all, I have the following problem, I have a Hot Spot implemented with a RB-450G and the performance is better that the RB-1000. I am taking about the CPU average …!!! Why…?
ROS=4.2
Regards,
Jose Blanco
Are both configured exactly the same? Is the user load the same?
Yes are, both configured exactly the same, and the user load is the same…
also i have the same problem. the cpu work at the 100% with a new configuration
i would suggest to double-check the configuration. maybe there is something that borks it
same problem happen to me. i discovered that the problem was a hardware problem. the processor cooling fan stops working so the processor is overheating. everything comes back to normal after fixing the fan. my router processor now works at 4-7% at all the time.
I have done a system reset-configuration each time I set it up, the configuration is always the same as you put the RB-450G. I don’t understand why the RB-1000 has very low performance.
The FAN are working well. :confused:
Jose Blanco
que raro lo de tu caso, no tengo experiencia con las RB1000 pero si con las RB450G y funcionan barbaro, proba con la version 3.X capaz sea un bug.
saludos
meno, ya habia probado con ROS 3.30 y 4.0, lo voy a probar con la 4.3 a ver que resultados obtengo.
meno, I did test with the ROS 3.30 and 4.0, I try again with the new version 4.3, I will write the results.
Regards,
Jose Blanco
Guys, I have a problem in my backup configuration, I have done a system reset-configuration, and configured all step by step and surprise… My RB-1000 just now working fine… :smiley:
Thanks a lot everybody…
Jose Blanco
