RB 1100 AH no boot fatal error
hy guys sorry by my english i am from brazil.
I buy one rb 1100ah 3 months ago, when comes to me i tested so far ok.
After the test i not turn on anymore, now i will use the and problem appears.
RouterBOOT booter 2.37
RouterBoard 1100AH
CPU frequency: 1066 MHz
  Memory size: 2048 MB
Press any key within 2 seconds to enter setup..
trying bootp protocol......... failed
kernel loading failed
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
modprobe: could not parse modules.dep
/etc/rc.d/run.d/S02logring: 10: cannot create /dev/log241: No such device or add
ress
/etc/rc.d/run.d/S02panic: 2: cannot create /dev/log241: No such device or addres
s
/etc/rc.d/run.d/S05syslog: 4: cannot create /dev/log240: No such device or addre
ss
/etc/rc.d/run.d/S07rb: 4: cannot create /dev/log241: No such device or address
/etc/rc.d/run.d/S07watchdog: 3: cannot create /dev/log241: No such device or add
ress
/etc/rc.d/run.d/S08softdog: 3: cannot create /dev/log241: No such device or addr
ess
Starting services...
/etc/rc.d/run.d/S10nova: 6: cannot create /dev/log1: No such device or address
Fatal error 0x853
Please contact support@mikrotik.com
socket failed (errno=97)
Shutting down...
Stopping services...
/etc/rc.d/run.d/C95panic: 2: cannot create /dev/log241: No such device or addres
s
Power down.
System Halted, OK to turn off power
Any help?
