RB 1100AH REBOOT
I need help my rb 1100ah restarts when I put all the ports on a bridge and apply quality of service, I had to downgrade version 5.1 to version 4.17 with this fix the problem but would like to know which solution I can give since version 5.1 has great advances
Please give us more detailed description of configuration you are applying. Is autosupout.rif file generated when the router reboots?
