RB 1100AHX2 system manufactures and RouterBOOT booter 2:38 RouterOS 5.8
In an attempt to downgrade to version 4.17 RB no longer starts.
I tried to install from the netinstall versions 4.17, 5.8, 5.14 without success.
Upgrade to 2:39 Booter without success.
RouterBOOT booter 2.39
RouterBoard 1100AHx2
CPU frequency: 1066 MHz
Memory size: 2048 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… not an elf header
kernel loading failed
I had same problem. I have tried to upgrade ROS version but router never starts. Then I tried to install new ROS using Netinstall. Some PC failed to install new ROS using Netinstall. For example: My Dell N5010 never works with MAC based applications. (MT neighbor veiwer, Winbox mac login, Netinstall etc). Maybe there is some problem with NIC card. It can discover MAC addresses but can not login or transfer files.
NAND formatted correctly
replacement of netinstall servers, network cards on servers, switches, does not help
What should I do? help me
Maybe it is possible to restore the chassis via a booting from microSD ?
