RB 1100AHx4 is not working
Good afternoon!
Router model RB 1100AHx4
It started to hang (links are not lit, it does not ping, it is not available via Winbox and SSH), only a reboot helps.
I flashed it via NetInstall to version 6.49.2 Stable
We set up a simple configuration for accessing the Internet and several port forwarding, but this did not change the situation.
Can you tell me, please, what the hang ups may be related to?
Are you referring to a constant boot loop or some random reboots ?
With ROS 6.49.0 is working perfect. I’m running one.
Regards.
