Ok - I am a veteran MT user both in wireless and ‘standard’ routers. I’ve RTM.
That being said - I have an older Teletronics (TT) AP w/a Prism 11Mbps 200mw card in it. The LAN side is connected to a T-1. I have 5 other types of radios connected to the Teletronics AP. I am trying to connect a RB112 w/a SR2 using 128 (104bit) WEP. The RB 112 absolutey refuses to connect to the Teletronics AP - error - with an ambiguous error - non-specific error (1)… What the heck is a non-specific error??
Back to the task at hand - I have the TT AP in WEP shared key 128 bit mode - 13 hex pairs of numbers - I used two other brands of radios and have had no difficulty in connecting to the TT AP. The RB112 has 2.9.35 OS and 2.5 firmware installed.
So the question becomes why won’t the RB112 connect? I checked, re-checked the WEP code - I even setup a temp AP with the same WEP code (I used a RB532) and the RB112 connected right up… But it will not connect to the TT AP.
Anyone out there tried this and made it work?
Just for those of you going - ohh this guy is using WEP…tsk, tsk, well everything over this link is VPN so not to worry…
Thom Lawless
General Manager
RapidWiFi
