RB 112 as a Backbone and AP
Dear All,
I have 2 Mikrotik RB 112.
one with single mini PCI installed located at ISP tower, another one with 2 mini PCI installed located at my place.
One mini PCI use as a link to connec to ISP tower.
Since i have one Mini PCI not used in my 2nd Radio, can i use that mini PCI as a AP for my client?
If it’s possible, can anybody tell the configuration, i’m tottally blank for this device.
Hi yanuarputra, Yes you can use your 2nd Radio as your clients AP. :smiley:
  1. create a bridge on 2nd AP
  2. add wlan1 and wlan2 to the bridge.
  3. add IP address to bridge
OK, I’ll try it in my radio
why dont you use rb532a , it is better than rb112
i use rb100 series for cpe’s only , it is the best one :laughing:
I used RB112 for hotspot ap with no problem. I have a few with 2 radio, one for backhaul on 5GHz and wifi hotspot on the 2nd radio.
Further down I got few 532A as hotspot gateway and further down usermanager as radius. connected thru point-to-point also on rb112.
Rb112 config only as AP, no firewall queue nothing.
Firewall and queue done on Rb532a and usermanager pc
This config works for me.
