RB 1200 Different Ports show Different Connections
First time Poster.
I have done a bunch of RB750G/GLs and a few RB450G units.
But this has me puzzled.
I built the config on this unit from the ground up.
I have DHCP Client on Ether-10
I have DHCP Server on Ether-1
Ports 2-5 are slaved to Ether-1
If I connect my computer to ports 1 or 5 it shows a 100 Meg Connection.
If I connect to ports 2-4 I get 10 Meg Connection.
What did I screw up???
Config below.
# may/14/2012 14:42:14 by RouterOS 5.16
# software id = G8K7-FFS6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:0C:42:9A:D2:0F mtu=1500 name=ether10 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:0C:42:9A:D2:10 mtu=1500 name=ether9 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:0C:42:9A:D2:12 mtu=1500 name=ether7 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:0C:42:9A:D2:11 mtu=1500 name=ether8 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:0C:42:9A:D2:13 mtu=1500 name=ether6 speed=100Mbps
set 9 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:9A:D2:18 \
    master-port=none mtu=1500 name=ether1 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:9A:D2:14 \
    master-port=ether1 mtu=1500 name=ether5 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:9A:D2:15 \
    master-port=ether1 mtu=1500 name=ether4 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:9A:D2:16 \
    master-port=ether1 mtu=1500 name=ether3 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:9A:D2:17 \
    master-port=ether1 mtu=1500 name=ether2 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
    cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
    split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
    shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
add name=pool1 ranges=192.168.10.100-192.168.10.150
add address-pool=pool1 authoritative=after-2sec-delay bootp-support=static \
    disabled=no interface=ether1 lease-time=2d name=server1
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none \
    stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
    default use-encryption=default use-mpls=default use-vj-compression=\
    default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
    use-compression=default use-encryption=yes use-mpls=default \
    use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
    ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
    metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
    out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/snmp community
set [ find default=yes ] address=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
set 5 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:D2:11:44:3D:0B \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
    disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.10.1/24 disabled=no interface=ether1 network=192.168.10.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no host-name=\
    WANInterface interface=ether10 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.10.0/24 dhcp-option="" dns-server=192.168.10.1 gateway=\
    192.168.10.1 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 servers=192.168.12.1
/ip dns static
add address=192.168.10.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input disabled=no protocol=icmp
add action=accept chain=input connection-state=established disabled=no \
    in-interface=ether10
add action=accept chain=input connection-state=related disabled=no \
add action=drop chain=input disabled=no in-interface=ether10
add action=masquerade chain=srcnat disabled=no out-interface=ether10
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether10 disabled=no
set ether9 disabled=no
set ether7 disabled=no
set ether8 disabled=no
set ether6 disabled=no
set ether5 disabled=no
set ether4 disabled=no
set ether3 disabled=no
set ether2 disabled=no
set ether1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether10 queue=only-hardware-queue
set ether9 queue=only-hardware-queue
set ether7 queue=only-hardware-queue
set ether8 queue=only-hardware-queue
set ether6 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether1 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
    trap-target="" trap-version=1
/system clock
set time-zone-name=America/New_York
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] disabled=no port=serial0 term=vt102
/system identity
set name=MikroTik
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=64.236.96.53 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
set 11 cpu=auto
set 12 cpu=auto
set 13 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=1GHz<400DDR> enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
    "" filter-mac-address="" filter-mac-protocol="" filter-port="" \
    filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
    only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
What version of RouterOS are you using?
The output file is correct and current in that it is running 5.16.
Should this be sent to support?
