RB 1200 sometimes freeze when reboot
Experts.
I have an RB1200 working fine with V6.2
It can be running for long time without problems. But, if i reboot it or if power failure occurs, when the 1200 reboot maybe can be freeze or maybe can reboot normally an continue workimg.
Any idea??
Thanks a lot!!
Here are a couple of things to try. A) upgrade your ROS, B) if that is not an option, re-install the OS with netinstall, C) connect a serial terminal to it to log what is going on when it reboots. Chances are re installing the OS will fix that. Have you submitted the support file to MikroTik?
