RB 133 slow with 4x and pppoe
Most of my 133 / 133C3 / 112 is working very slow if I use them as a router with pppoe enabled.
When pppoe is disabled everyting is fine.
Is there any reson for that?
Somtimes pppoe wont connect, other times pppoe is connected, but nothing works until a reboot..
(Bad english.. I know..)
These are old models, they could be slow on heavier load. How many clients do you have connected?
These are used as client antennas. CPU goes to 100% for a long time when pppoe is enabled. But the weird thing, is that some boeards work great. If everyone was slow, i would accept that it’s old slow boards, but with the same config, same packages, same ROS they work different.
If we take a slow board, and use it as a bridge, it works fine..
Is there anyting i can check on the slow board to make it work better?
try RouterOS v5rc3. It has the new CPU load monitor. It will tell you exactly what eats the CPU in those other boards. Check menu “/tool profile”
Thanks. I will try that
make sure to install only the packages you use. for example “system, wireless, ppp”
So far it looks like flash is using most of the CPU when the RB “freezes”…
Some of the boards is “online” (pppoe connected) but ping is not responding. If i’m able to MAC telnet into the RB, it shows the IP adress on pppoe-out but cant ping. (no route to host) after restart they can be “fine”
When the boards are like that MAC ping from AP is very unstable 170ms to 800ms with many timeout
Will it help if I took a supout from an unstable board and sent you?
Perhaps the flash is going bad on some of your boards?
Try upgrading the bios
system / routerboard / upgrade
They have 2.18.
Is there any way to “repair” that?
bump
This exact same problem of 100% CPU with RB133 using PPPoE Client over wireless is evident in every single known version of MT since v3.0 and upwards. EXCEPT v3.19 is fine so this is the version we have had to standardise on.
New boards we use are RB411 and they are fine. But the problem is the 100’s of RB133’s we already have deployed so we cannot upgrade!
PLEASE, mikrotik can you fix this. It is very easy to replicate. Just enable PPPoE client in any wireless RB133 running version higher than 3.0 (but not 3.19) and it hangs with 100% CPU.
We just tested and version 4.16 is still the same too. So you should simply test with this current version and you will be able to replicate.
We have tried and tried and tried to get a supout.rif for MT support but with 100% CPU it’s impossible!
Without PPPoE Client enabled the RB133 works just fine. It’s ONLY the PPPoE client that causes 100% CPU and always hangs.
u have too format flash with netinstall and they working fine but firs export the key
