i start with Ethernet Cabel on eth1 and the Light of ether 1 beginns to blink, after 20 sec. the eth6 is blink and eth1 ist off, but my cale is on eth1.
And in all constellation i never can conect to the Routerboard to mac or IP 88.1
if i insert a cabel in eth6, eth7, eth8, eth9,eth10 no lights will go on.
Ether1 (if default configuration is not removed) is WAN port and you will not be able to connect to the board from this port. You can connect only from ether2 to ether10.
Try to connect to ether2 and see whats going on with ports 6 to 10.
Thank you for the answer, but i am testing all ports from ether1 to ether 10 with default IP Adress an the Winbox.
Only ether 2, ether 3,ether 4 an ether 5 will activate the LED but no response. On ether 6 - ether 10 i get no connectivity.
Do you have any idea?
Thank you.
