Did somebody use any Huawei MINI GBIC in Rb 3011? Does it work such as Optical Transceiver(SFP+,1310nm,10Gb/s,-8.2~0.5dBm,-12.6dBm,LC,SM,10km) ?
Please let me know whether is may be compatible with the Rb 3011uias-Rm L5.
MINI GBIC Part number: OSX001002
RB3011 has an SFP port (1.25G), not SFP+ (10G).
What do you want to link by fiber? what’s the distance?
I with to connect a 8 Km backbone from a local ISP and the 10 gb could be a plus for accessing the akamai services in there.
If you want 10G, then you’ll need a different router, with 10G (SFP+) interfaces and power suitable for 10G, a CCR1009-7G-1C-1S+ as bare minimum.
If you’re an (W/F)ISP and not a “power user”, then I’ll skip straight to a CCR1036-8G-2S+ as it’s the sweet spot in terms of price/performance, being a futureproof investment.
Suitable SFP+ Modules for your application: S+31DLC10D. Make sure Local ISP router supports them (most probably).
Thanks for the explanation sir =). I will check’em out then.
