Hi to all, I have a problem with my RB411 board look like i disable ether1 with winbox not its not seeing the RB, how can i reset it to default?
Nicmo
Nicmo
You can enter the board via COM port and enable ether1. It’s not necessary to reset the board.
Thanks for the reply, I tried to connect via com port but the screen auto scrolls. Any suggestions?
Nicmo
Did you select a baud rate of 115200? Access through the serial port should always work.
Yes I did.
115200 and press enter in Terminal… and It should work : /
you can enter terminal and connect the board.. then you’ll see letters, if you see symbols, try another baud rate.
Maybe the cable was too long so i build a shorter one and it works great.
Thanks for all the suggestions.
